P0336
Old Nov 7, 2007 | 03:39 PM
ohsolow's Avatar
P0336
So i replaced the opti today and when i went to start the car it turned over really hard like the timing is way advanced. Then it set a P0336 code. There is no way you can put the opti in wrong is there? The dowel pin only fits in one groove right? I have changed several of these and never had this problem. The opti is a new AC Delco one that i had bought a few years back but never used.
The car is a 1997 Trans Am A4
Any suggestions?
Thanks,
Ian
Old Nov 7, 2007 | 03:54 PM
The Engineer's Avatar
I don't know how, but I've heard that people have missed the Opti hub slot with the cam pin.
Also, when changing an Opti it is always best to do a quick (short) test start and run before installing the water pump and coolant and all the other stuff to see if everything is OK.
WD
Old Nov 7, 2007 | 05:23 PM
ohsolow's Avatar
WD
That is exactly what i did. The pin went in where the bolt next to it was supposed to go. It was weird the mounting plate sat pretty well flush up against the timing cover. I don't see how that was even possible.
Thanks, everything is better now.
Ian
ZX636RIDER03
Feb 19, 2013 01:39 PM
ta_ws6
Jul 14, 2009 11:48 PM
intense1997lt4
May 19, 2008 10:13 AM
intense1997lt4
May 16, 2008 04:23 PM
moparman
Jul 9, 2007 06:39 PM
