P0336
P0336
So i replaced the opti today and when i went to start the car it turned over really hard like the timing is way advanced. Then it set a P0336 code. There is no way you can put the opti in wrong is there? The dowel pin only fits in one groove right? I have changed several of these and never had this problem. The opti is a new AC Delco one that i had bought a few years back but never used.
The car is a 1997 Trans Am A4
Any suggestions?
Thanks,
Ian
Any suggestions?
Thanks,
Ian
I don't know how, but I've heard that people have missed the Opti hub slot with the cam pin.
Also, when changing an Opti it is always best to do a quick (short) test start and run before installing the water pump and coolant and all the other stuff to see if everything is OK.
WD
WD
WD
WD
That is exactly what i did. The pin went in where the bolt next to it was supposed to go. It was weird the mounting plate sat pretty well flush up against the timing cover. I don't see how that was even possible.
Thanks, everything is better now.
Ian
intense1997lt4
May 19, 2008 10:13 AM
intense1997lt4
May 16, 2008 04:23 PM
