P0304 Cylinder 4 Misfire Update
Old Oct 29, 2006 | 07:52 PM
doug1105's Avatar
Okay so I was getting a misfire on cylinder 4.
I changed all the plug wires on the passenger side 3 times. Then I took everybody's advice to look at the plugs even when I didn't think it could be the plug.
Well here's the plug I pulled out of cylinder 4-
I tried putting in a new plug and started it up and it started misfiring again.
I pulled that plug after less than 5 minutes and it looks like this-
Whattaya think?
Old Oct 29, 2006 | 09:11 PM
1 slo 6's Avatar
u might have a bad injector looks like that cylinder is running rich... swap out an injector and see if it changes from one cylinder to another. it also looks like u r burning some oil u might also have a bad set of rings. did u check compression....?
Old Oct 29, 2006 | 09:42 PM
doug1105's Avatar
I didn't check compression yet but yeah the plug looks like somebody dipped it in tar.
Rod Bender
25
Sep 16, 2015 01:47 PM
Girrrrl
Aug 20, 2015 09:26 AM
Girrrrl
Aug 20, 2015 06:17 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
Noct
Jul 14, 2015 01:18 AM
