P0155 and closed loop?
Old Jan 2, 2006 | 06:50 PM
antman's Avatar
Can the PCM enter a closed loop if there is a faulty oxygen sensor? In reading my Haynes, it says that then the PCM won't enter closed loop if there is a problem with the oxygen sensor. I have P0155 and P0133. I hooked up a scanner to the car while it was running and the scanner showed the PCM to be in closed loop despite the SES still on.
Old Jan 2, 2006 | 08:57 PM
Re: P0155 and closed loop?
P0133 is for slow response, Bank 1 pre-cat. The code can only set if the PCM is in closed loop. P0155 is for a faulty heater circuit on Bank 2 pre-cat. The sensor can still be functioning, it just may take longer to heat up.
The PCM just looks for O2 sensor activity, to indicate they are heated up and working. Once it sees the activity, it switches to closed loop. One of your sensors is moving slow, but its still "working", the other has a problem with the heater circuit, but apparently its getting hot enough to show the required activity and kick it into closed loop.
93 RedBird
Nov 15, 2015 08:24 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
tommalcolm
Sep 11, 2015 03:39 PM
Toxintwins
Sep 11, 2015 11:13 AM
tdigger9899
Sep 7, 2015 10:56 AM
