p/v clearance
Old Mar 21, 2005 | 09:43 PM
95formy's Avatar
p/v clearance
if i install 1.6 rollers with a cc306 cam ,will i have any p/v issues with stock pistons?
thanks Billy
Old Mar 21, 2005 | 10:01 PM
SStrokerAce's Avatar
Re: p/v clearance
No you shouldn't. The valve events don't come close to PTV problems and the stock valves are small enough that it doesnt matter.
Bret
Old Mar 22, 2005 | 07:11 AM
95formy's Avatar
Re: p/v clearance
cool i was worried thanks for the info
Billy
Old Mar 22, 2005 | 08:21 AM
GetaZforgetGT's Avatar
Re: p/v clearance
Bret
Let's say that you take a stock setup as mentioned above and you change the block.
In my case I have a cam, heads, valvetrain combo that was running on a stock block with no clearance issues.
My new 383 will have the piston 10 in the hole...do you think I might have issues with valve clearance?
Thanks,
Jeff
Z Power
Sep 19, 2015 11:19 PM
karpetcm
Sep 15, 2015 11:07 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
Beave2780
Wheels and Tires
Sep 5, 2015 06:30 PM
Aug 5, 2015 08:35 AM
