Oversize Crank Sprocket for LT4 Heavy Duty Timing Set worh it?
Old Jun 22, 2004 | 05:13 PM
AdamZ1LE28's Avatar
Does it add performance? It's only like $40 so is it worth it?
-Adam
Old Jun 22, 2004 | 06:34 PM
AdamZ1LE28's Avatar
Someone out there must be using it and know a thing or two about it....
Old Jun 22, 2004 | 06:55 PM
mrz28 73/97's Avatar
The oversized sprocket is for use when you have rebuilt your engine and had your mains align bored/honed bc you have added splayed caps and or studs to your mains. When this happens the distance between the crank and cam is shortened and you end up with slack in the chain. To remedy this GM made the bigger sprocket to take up the slack, so unless you've had the above mentioned work done to your block or you just have slack in your chain you won't need the oversized sprocket.
Old Jun 22, 2004 | 08:43 PM
1racerdude's Avatar
sprocket
The Cloyes "oversize" sproket is not really oversize. Cloyes makes Chevy timing sets to GM spect.GM spect calls for a smaller than normal crank sproket.I think to compensate for water pump load? The Cloyes set has a standard gear which is "oversize" to GM spect,But normal size for a small block.If you are not running an electric WP I would suggest you stay with the GM spect timing set. There is no performance advantage on a mild or stock motor.
LeftoverChinese
Jan 14, 2024 03:03 PM
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
