overheating to well over 300 degrees
Old Jun 20, 2006 | 08:30 PM
DLindlZ28's Avatar
anyhow one morning i crunk up my car and white smoke just poured out for about 5 mins then it stopped and no problem after that until later in the day my radiator hose popped from overheating changed it out and refilled with coolant and now it over heats passed 260 in less than 2 mins. its a 93 z28 with a brand new water pump and the radiator is cycling water.
Old Jun 20, 2006 | 09:05 PM
SStrokerAce's Avatar
Re: overheating to well over 300 degrees
It's a temp sensor problem most likely, make sure that they are all working properly. Are you sure nothing is making the thermostat stick?
Bret
Old Jun 20, 2006 | 09:09 PM
Victory Racing's Avatar
Sticky stat sounds like the culprit to me. I'd investigate the stat further.
Old Jun 20, 2006 | 09:35 PM
If white smoke poured out on startup, you have a blown head gasket.
Old Jun 20, 2006 | 09:37 PM
Yeah that part sucks as well!
Old Jun 21, 2006 | 07:58 PM
DLindlZ28's Avatar
i changed the temp sensor and its still overheating. i can crank it up right now and it dont smoke have tried the termostat yet
Old Jun 21, 2006 | 08:13 PM
speed_demon24's Avatar
Did you bleed the air out of the system when you filled it back up?
Old Jun 22, 2006 | 02:06 AM
87lt1rx7's Avatar
I want to know how it hits over 300 I thought the computer would shut it down if it ever ran too crazy hot
Old Jun 22, 2006 | 02:20 AM
Daniel6718's Avatar
headgasket? waterpump drive gear on my car stripped due to air in the system
Old Jun 22, 2006 | 06:28 PM
DLindlZ28's Avatar
no i did not bleed the system i didnt know u had to.... anyhow how do you bleed it and i just bought the water pump a month ago and drove the car like 6 times
Old Jun 22, 2006 | 06:35 PM
Johnnynsac's Avatar
White smoke on start up indicates you probably have a head gasket leak.
Old Jun 25, 2006 | 04:55 PM
BIG SHAFE's Avatar
Third that.
Old Jun 25, 2006 | 06:51 PM
chevelles101's Avatar
I am having the same sort of problem. I keep trying to bleed the stupid thing, but it seems like an endless amount of air is coming out. When I open the bleeder on the large hose/thermostat housing nothing but coolant comes out, and when I open the bleeder on the smaller hose it will spurt coolant then some air then some coolant and so on. I just can't figure it out. Someone please help.
Old Jun 25, 2006 | 07:31 PM
Kevin Blown 95 TA's Avatar
Got any coolant loss?
Old Jun 25, 2006 | 09:00 PM
indirocz28's Avatar
When Bleeding the coolant system- make sure you have water in the radiator, put your overflow and radiator cap on and down sealed tight. Start the car and let it heat up a bit and make sure the thermostat opens, then find the bleeder screw on top of the T-stat housing and crack it open. Air WILL spray out, and if it is hot, it will more than likely be steam. You want it to bleed until a steady stream of water SHOOTS out, belive me- it will shoot out.
