overheating to well over 300 degrees
Re: overheating to well over 300 degrees
Thanks for the replies. I figured out it's just the sensor, because after long periods of idling and driving I can open the radiator cap without coolant spewing everywhere. I went to the dealership saturday to get a new one and they had the sensor itself but not the connector so I don't know what to do about this whole thing.
Your connector is bad?
What sensor?
Yes, there is coolant in the radiator. The sensor in the head that sends signal to the gauge in the dash which tells you what your coolant temp. is the one I am speaking of.That sensor I am speaking of is from autozone. The dealership has this sensor, but they don't seem to have the matching connector or plug if you will. I am going back to the dealership today to see if someone else there can help me.
I may be wrong but if you headgasket is leaking, air may keep getting in the cooling system through that leak while the engine combusts and it goes througt the crack in the gasket.
Originally Posted by 96_pimped_out
I got it, and I laughed my *** off... It's a Little Jon quote guys... "Crunk"? Hello?
Ahhh YEEEAAAAHHHHH BOOOIIEEEE
any good?
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Henson071
Sep 21, 2015 04:31 PM
CARiD
Sep 7, 2015 08:21 AM
