Overheating questions?
Old Aug 17, 2004 | 10:48 AM
vodoo-chile's Avatar
My car drove fine for over a year, never once getting over the first mark on the temp gauge. I drove my car in stop and go with the AC blasting in 100+ degree temps and hardly budged the needle. Well, last week, my tranny took another dump and I had it rebuilt. The only change made was going back to a stock type 2000 stall. Now, my car will start to overheat when I am driving. It will get up to and beyond the halfway mark, but only while moving. Once I come to a stop (at a light, etc) the temp will start to go down. Is it possible there is something with the tranny rebuild that is casuing this? I've checked the thermo and it is opening and closing, flushed the water, etc. the only thing and don't know about is if the water pump is working. There are no leaks from the weep hole or anything. Any ideas would be greatly appreciated. Thanks,
Kyle
Old Aug 17, 2004 | 11:57 AM
Re: Overheating questions?
No one happened to remove the air dam, did they?
Old Aug 17, 2004 | 12:14 PM
You know what, I don't know. That is the flat piece that sort of sticks down right underneath the bumper, right?
Kyle
Old Aug 17, 2004 | 12:43 PM
Shoebox, you are the man. When I had the car towed, the tow driver accidently pulled the airdam off. Picking it up today. Thanks so much,
Kyle
warmeck
Apr 16, 2015 05:50 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
