Overheating problems please HELP !!!
Old Jul 13, 2008 | 03:22 PM
AZ2ENVY's Avatar
I searched and didnt find anything too relevant . Here is the problem .
This is on the wifes 1995 Z28 . The car wont overheat right away it takes
about 10-20 mins of steady driving to do so . The car is now starting
to chug and act like it has a miss pretty badly . This is what ive done
to narrow down what the problem might be ....
New 160 Thermostat
New CSR Electric water pump
New Radiator
New Radiator cap
Manual fan switch on at all times
Pressure tested cooling system with car off and no leaks
No collapsed hoses
Car just started smoking white on startup but goes away
Im leaning towards head gasket but im really hoping not Any suggestions ???
Old Jul 13, 2008 | 03:44 PM
If you are suspecting head gasket, read the plugs. Test the cooling system for exhaust gases.
Old Jul 13, 2008 | 08:06 PM
ulakovic22's Avatar
White smoke is coolant so I bet you're right. It is obviously getting in the combustion chamber a little at a time and probably why it takes a while for it to overheat instead of it doing it right away.
Old Jul 13, 2008 | 10:31 PM
AZ2ENVY's Avatar
How do I test the coolant for exhaust gasses ???
liamcg97
Nov 25, 2019 05:55 PM
AlaskaZ28
Apr 17, 2015 08:54 AM
warmeck
Apr 16, 2015 05:50 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
