Overheating Problems
Old Jun 19, 2004 | 12:50 PM
SVT Killer LV's Avatar
I have a buddy with a 96 WS6. He installed some Jethot LT's back in November and his car started running really warm after it happened. He then continued to drive the car with the needle nearly at the red for about 6 months before decided to do something about it (after I have been nagging him the whole time to do it). Well now the waterpump, thermo, radiator have all been changed (told him NOT to do that, but didn't listen again). Still runs hot. The system is not holding pressure. I told him one of his HG's or both are done for, or he could have warped a head driving the car for such a long time at such high temps. What do you guys think? Discuss.
Old Jun 19, 2004 | 01:20 PM
HBHRacing's Avatar
did he bleed the system correctly?
did he put the right thermostat in it?
are the fans coming on?
is there a manual switch or programing for lower fan turn on temp?
if it;s not making pressure then I doubt it;s a head gasket, that will usualy create a ton of pressure. have you considered a new radiator cap? lots of questions in stead of answers but we need to rule out the simple stuff and geta better feel for everything. I would pay close attention to the fans.
Old Jun 19, 2004 | 02:15 PM
yes
yes
yes
manual fan switch
it has a new cap
fans are a coming on and are working
Old Jun 19, 2004 | 02:52 PM
HBHRacing's Avatar
ok. and your sure that there isn;t a leak anywhere? your not losing coolant and it's not showing up in the oil? so siting there at idle with the fans running it will still get really high? have you compared the temp sensor reading to the gauge reading? maybe it;s fine and just showing hot on the gauge
Old Jun 19, 2004 | 08:04 PM
gonna try that, if not then ill rip the heads off that car, have them checked out and drive that car into a lake
Old Jun 20, 2004 | 12:56 AM
HBHRacing's Avatar
lol. instead of driving it to the lake drive it to my house and sign it over to me
if you do think it;s the heads you can pick up a "block test kit" from NAPA that wil test for exhaust gasses in the cooling system
Old Jun 21, 2004 | 01:47 AM
ill run a couple more tests and see if that thing needs some brand new AFR's or something
liamcg97
Nov 25, 2019 05:55 PM
AlaskaZ28
Apr 17, 2015 08:54 AM
warmeck
Apr 16, 2015 05:50 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
