overheating problem
Old Oct 28, 2007 | 12:49 PM
silenthunderz28's Avatar
overheating problem
i have a 1997 z28 and i have been having problems with the cooling system for a while. when i started the car the other day it idled a little rough like the time i had to replace my rotor cap the service engine soon like started flashing but once the ses like stopped flashing the stumbling went away and it felt like i had all my power back but then about 3 minutes later i noticed my temperature started rising and i put the heater on and it kept rising almost to the red and i noticed that the heater was blowing out cool air as it started to overheat but then i noticed that the heater would start blowing out hot air again the temp would start going back down. i have never had this problem before i have replaced the sending unit to the gauge,the upper radiator hoses flushed the radiator put a new thermostat in about 2 months ago and had the water pump replace about 2 years ago. any help would be apprieciated
Old Oct 28, 2007 | 01:01 PM
dangalla's Avatar
have you tried bleeding the system it sounds like you may have some air in there
Old Oct 28, 2007 | 02:54 PM
i have tried that and its fine i just replaced the sending unit about a week ago cause the gauge pegged out at 260 and it wasn't overheating so i replaced the unit to the gauge and up until saturday it was running fine wouldn't ever pass 180 and now all of a sudden its back to the way it was but now i notice that when it looks like its going to try and over heat it starts blowing cooler air into the car instead of hot air out of the heater i don't know if this has anything to do with it stumbling when i first start the car cause it has only been stumbling when i first start the car in the morning when the car has been sitting for more than half a day or something
liamcg97
Nov 25, 2019 05:55 PM
AlaskaZ28
Apr 17, 2015 08:54 AM
warmeck
Apr 16, 2015 05:50 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
