Overboard
Old Dec 28, 2015 | 07:57 PM
Jdad1977#'s Avatar
Overboard
Just picked up my son's 94 z28 bored 40 over 58mm throttle body 50lb injectors lt4 hot cam longtubes 3 inch exhaust with loudmouth fogging fuel all the time sitting at light have to keep raving it like an old school blower motor 2800 stahl w shift kit were do I start w programing or tune any one lead me to a thread?
Old Dec 29, 2015 | 09:51 AM
Re: Overboard
Let's move this from "New Member Into" to "LT1 Based Engine Tech", where tech problems are discussed.
You need to tune the PCM for the grossly oversized 50 #/HR injectors. Why would you put them in an engine with a HOT cam? Stockers would be fine. If you still have the stock injectors put them back in.
If you want to keep the 50's, get a copy of LT1_Edit for OBD-1, and tune it yourself. Or get a mail-order tune from someone like pcmforless:
PCM for Less
And stop driving it.... the excessive fuel is bypassing the rings and washing the lubrication off the cylinder walls, and diluting the engine oil.
Old Dec 29, 2015 | 11:36 AM
Jdad1977#'s Avatar
Re: Overboard
Apologies trying g to do this from cell phone stuck in daytona. Had the injectors in it when I bought it I know the lt4 hot cam and bores 30 over going to pull injectors next week when I get home and worst case use ones off my formula to try to line out
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
warmeck
May 1, 2015 11:30 AM
TrouserSnake
Aug 3, 2002 04:08 AM
Smokn '94 Z
Jul 28, 2002 02:38 AM
