over valve wire kit just in
Old Jan 16, 2004 | 02:18 AM
NewbieWar's Avatar
well i ordered mine from tunder racing and i got it from them, but i was just curious when i told u guys i was buying them u guys said it was bad that i was on manafolds so do u think i should wait till i get headers before i install them?
Old Jan 16, 2004 | 02:23 AM
tryintogofast's Avatar
I'd probably wait. The problems are that for one your line fo sight is no where near as good with headers. You would have a hard time knowing whether or not one of your plug wires was resting on the manifold. Second the heat shields on the manilfolds will probably get in the way as far as tryin to keep the wires off the hot spots. You can probably do it but you'll probably have multiple misfires in the near future. Just my opinion.
Old Jan 16, 2004 | 02:31 AM
97WS6SCharged's Avatar
You can do it with the manifolds, just make sure you have plenty of zip ties handy.
Old Jan 16, 2004 | 10:24 AM
drewstealth's Avatar
I would just wait also. Not really worth the hassle imo. The manifolds will make it a lot tougher. You don't want to burn one of the wires and have to order another set.
Old Jan 16, 2004 | 11:16 AM
Will84's Avatar
Wait till after the header install. It will be a lot easier to do once the headers are installed. Also, the wires may need to be cut slightly different when your headers are installed.
Make sure you get headers that do not have smog connections. The AIR tubes on the headers will interfere with the front loom on both sides (Edelbrocks will anyways). I had to turn my looms up the other direction... it doesn't look bad, but it's not as clean as I would like.
Old Jan 16, 2004 | 11:31 AM
Zack's Avatar
using them with manifolds doesnt sound like a good idea. Thats just asking for burnt wires
LeftoverChinese
Jan 14, 2024 03:03 PM
RUENUF
May 25, 2016 08:10 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Don 97 SS
Jul 11, 2005 08:50 AM
