over-rotated wiper
Old Feb 10, 2004 | 04:12 PM
StangInRearView's Avatar
over-rotated wiper
did a search cant find anything, my driver wiper rotated past my a-pillar, when i put them in the rest position, i can move the driver side up and down, not the passenegr. Is this a wiper arm problem, linkage problem, or motor problem???
Old Feb 10, 2004 | 05:28 PM
94blackz14.2's Avatar
Check to make sure the nut that holds the wiper arm down is tight. My mothers Jimmy had what sounds like a similar problem that you are having and all it turned out to be was that the nut needed to be tighten down. It is located at the bottom of the wiper arm and you have to pop off the little cap to get to it. Hope this helps.
Red Hawk 94
Mar 18, 2019 04:03 PM
autoxr166
Sep 25, 2015 04:21 PM
stopthatman
Feb 9, 2015 09:00 PM
Kris93/95Z28
Feb 27, 2003 01:04 PM
Mr Freeze
Feb 11, 2003 08:19 AM
