over heating?????
Old Feb 7, 2011 | 02:21 PM
1nicelt1's Avatar
over heating?????
Ok my car was overhating I changed the warterpump and hoes adde a 160 degree thermostat and it's over heating faster then it use to befor the the new water pump instal at first I thought it was the coolant temperature sensor but could the thermostat not be opening up?
Old Feb 7, 2011 | 03:22 PM
Guest47904's Avatar
Guest
Re: over heating?????
Do the fans come one either on their own or with the ac on?
Did you pull the rad. support plate off to see if anything got in front of the radiator?
Have you topped it off while you visually saw flow inside the cap and shut it off and checked the level the next morning?
Old Feb 7, 2011 | 03:23 PM
jlew69's Avatar
You may have air in the lines. I would rebleed the coolant to make sure all of the air is out.
Old Feb 7, 2011 | 06:01 PM
Did you get the correct thermostat for the LT1?
Courtesy of Shoebox:
http://shbox.com/1/tstat.jpg
The thermostat doesn't control the overheating. The temp is controlled by the fans, as operated by the PCM.
What temperature is the dash gauge indicating when you feel it is "overheating"?
Do you have access to a scanner to allow you to observe the coolant temperature being sent to the PCM from the temp sensor in the water pump housing?
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
CARiD
Sep 30, 2015 05:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
