output driver module?
Old Dec 5, 2005 | 08:00 PM
95okz28's Avatar
I just had my 95 z28 scanned today and got code 29 which is the odm from what they said. But the other mechanic told me that it was the ignition control module and gave me a diffrent location for it. so where and what is this odm?
Thanks for the help.
Old Dec 5, 2005 | 09:31 PM
Re: output driver module?
Not sure where those people get their info but DTC 29 is for the AIR pump. Check the fuse under the hood.
It is a common problem and there was a recall for most 95-97 models.
Old Dec 5, 2005 | 10:19 PM
95okz28's Avatar
Checked the fuse and it was blown. Could anyone tell me what i need to do so i dont have to keep replacing it? And could anyone tell me what the output driver module is?
Old Dec 5, 2005 | 10:31 PM
They probably meant QDM (Quad Driver Module). That only applies to 1993s.
If the fuse keeps blowing, the AIR pump is drawing too much current. It needs to be replaced or have the recall done. You could always just unplug it, too. It won't bother much on a 1995 as long as the fuse is good. If you have emissions testing, then you will need to have it fixed.
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
dluna333
15
Mar 13, 2015 12:30 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
Jul 4, 2005 05:00 PM
