LT4 Valve cover studs fit LT1 valve covers
Old Dec 5, 2005 | 02:50 PM
OBE1 95Z28's Avatar
If your remove the internal "webbing" on a LT1 valve cover, will the LT4 studs fit (proper height)?
Old Dec 5, 2005 | 03:35 PM
Admiral94's Avatar
Re: LT4 Valve cover studs fit LT1 valve covers
They should as the LT4 valve cover is the same as the LT1 minus the drip rails since the LT4 used RR.
Old Dec 5, 2005 | 04:03 PM
I don't think they will work at all. The LT4 covers use a totally different way of sealing the stud and nut and the covers are not the same height. The LT4 is a completely different cover.
Old Dec 5, 2005 | 09:52 PM
firebirdStud's Avatar
not stepping on toes, but several people run them on LT1's. I learned that here. I am looking for a set for my car right now. Evidently they do match up. If they don't, I will be really mad!
Old Dec 5, 2005 | 09:59 PM
Well, yeah, I'm using the LT4 valve covers, but the question was can the LT4 studs work on LT1 covers (unless I misunderstood ).
Old Dec 5, 2005 | 10:07 PM
OBE1 95Z28's Avatar
Shoebox is right on target!
Old Dec 5, 2005 | 10:33 PM
haha, my bad. sorry for bein retarded shoebox! I guess if you are going to post, maybe you should read alittle better! )
HectorM52
Jul 30, 2017 11:46 AM
MadMav
Feb 6, 2015 11:02 PM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
