out of tank feul pump? how?
Old Sep 13, 2003 | 01:03 AM
DTABFORMULA's Avatar
Question out of tank feul pump? how?
i want to go with a fuel pump out of tank and i have no idea how to do it can anybody explain. if u have time shoot an email and explain please i really think im gonna attempt it. what will i need? im so confused
thanks
Old Sep 13, 2003 | 01:15 AM
RamAir95TA's Avatar
You're going to need to remove the in-tank pump.
I don't understand why you'd want to do this though? Why not invest in a good in-tank pump and run a piggy-backed inline pump? (nitrous or boost?)
Old Sep 13, 2003 | 08:11 PM
nos car only im not running it on motor.
im spraying a 250 direct port...i want a big fuel pump to be able to work...do u know how it works...
Old Sep 13, 2003 | 11:05 PM
LPEdave's Avatar
Here's my setup, and there are links to a couple others in there too.... http://www.go-fast.org/z28/fuel.html
Dave
Old Sep 13, 2003 | 11:09 PM
Transamdriver's Avatar
A racetronix FP system with MSD booster should be able to handle that right?
Old Sep 13, 2003 | 11:21 PM
BadAssed93Z's Avatar
i just put a walbro 255l/h inline pump in my friends nitrous car and it was cake.
it came with his n20 kit. it involved getting under the car cutting about a foot of the METAL fuel line, mounting the pump in its place, and wiring it in to the ACC fuse through the rubber grommet under the drivers seat. took about 45 minutes due to a miniature pipe cutter and having to bend the pipe a little to allow for clearance.
Apr 24, 2015 01:03 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
Deadbolt24
Jan 19, 2015 01:29 PM
ANDYZ28
Dec 29, 2014 09:13 PM
