OTVC Wire Question? Pic inside!!
Old Jun 28, 2004 | 02:44 AM
94TA25ann's Avatar
I finishing up on my Jet Hot LT install and just got through doing the wires. I bought ThunderRacings kit they sell for 100.00. I routed the wires on the passenger side under the altenator. When I put the altenater in I noticed that it was touching the wires. My question is will this burn the wires or cause any problems? Someone please let me know soon.
http://memimage.cardomain.com/member...50_12_full.jpg',%20575,%20461)
Old Jun 28, 2004 | 03:29 AM
dhirocz's Avatar
I cant think of that causing any problems, but maybe there's something I'm not seeing here. As far as burning, I certainly hope your alternator isn't getthing that hot! j/k You should be fine. Maybe somebody else can confirm this...?
Old Jun 28, 2004 | 06:33 AM
scoobysnax83's Avatar
nope, you'll be fine...
Old Jun 28, 2004 | 12:42 PM
94TA25ann's Avatar
Thanks guys...I didn't want to have to buy another wire set just to redue that side.
Old Jun 28, 2004 | 12:47 PM
94TA25ann's Avatar
It would have been better if I routed them around the alt., but i didn't think of that at the time. Which way did you guys route yours on the passenger side?
Old Jun 28, 2004 | 07:53 PM
I'm pretty sure I did mine the same...
Old Jun 28, 2004 | 08:53 PM
Kataklysm's Avatar
Mine goes around...I know the alt gets hot but I'm not sure how hot. Theres a pic in my sig (its hard to see the black wires on the valve covers)
Old Jun 29, 2004 | 03:01 PM
IslandZ's Avatar
If your **** like me you can get some split loom (the stuff the harness wires go through) and put the wires in there, it looks cleaner and I doubt they will burn through the plastic and through the wire.
Old Jun 29, 2004 | 04:33 PM
94TA25ann's Avatar
I am very **** about my car aswell. I'm just going to try it out and if I don't have any problems great and if I do I'll just have to buy another set and redue the passenger side.
Old Jun 29, 2004 | 09:27 PM
IrocSS85's Avatar
I think the vib.s alone might cause a problem overtime. add some heat (prolly about the same heat as the intake will see) and I wonder how long it will last. at this point, you migth aswell go ahead and give it a whirl. maybe I'll be wrong and it wont give you a problem. I'll send you a pic of how I routed mine if you do have to redo them later.
chris
Old Jun 30, 2004 | 01:05 AM
94TA25ann's Avatar
chris
I ordering another set tomorrow. Thanks for the pics. I'm either going to do ityour way or around the alt. All post some pics of my jet hot install in a week. The car is 2 hours away at my moms and the only time I have off school and work is on the weekends, so whatever i don't finish has to wait another week. All I have left is to bolt the alt. in, starter, dipstick, ypipe, cut air hardline.
Old Jun 30, 2004 | 01:31 AM
Alex94TAGT's Avatar
I had MSD 8.5's routed directly underneath the alternator for about two years. It was hot enough under there to slightly deform thin plastic (convoluted tubing), but certainly not hot enough to burn a high-temp ignition wire. I dont think you've got anything to be alarmed about.
Then again, I also had a few of the plug boots practically touching header primaries (maybe 1mm of clearance), and they didnt burn or discolor either. When I removed the wires and cleaned them, you'd have thought they were brand new out of the box.
Luck of the draw I guess -- I know others haven't been as lucky. Always good to have a spare set of ignition wires handy...
Old Jun 30, 2004 | 05:14 PM
LWillmann's Avatar
I routed mine the same way.
I haven't had any of them melt, but I had some cross-arcing. Spark jumping from wire to wire, so I put convoluted tubing on them. I need to check them again at night and see if it's any better.
Old Jul 1, 2004 | 01:16 AM
94TA25ann's Avatar
How can you tell if they are arching and how do you fix it. Will your car run like crap(very noticeble or not)?
Old Jul 1, 2004 | 03:00 PM
O-taka's Avatar
i used some flexible silver insulator tubing, but the convoluted stuff should work too.
once they start arcing, they won't stop, gotta change em
you can see it at night if you pull on the throttle cable (or have someone gun it)
