Other options for Meziere/CSI pump freeze plug?
Old Nov 3, 2003 | 03:06 PM
jimlab's Avatar
I found a crack in the water pump on my engine... which certainly clears up the source of the rust trail down the front of the block. I should have known better than to send down a used pump (it appeared to be in very good condition, but still...) to use on my engine. The problem is that when my Meziere electric pump was installed, the freeze plug was cemented in place.
I've ordered a new pump (housing), and although I'm sure I could probably get a replacement from Meziere, is there a readily available freeze plug size that works for situations like this?
Old Nov 3, 2003 | 06:33 PM
Mtrhds94Z's Avatar
It's a 1-1/8" brass freeze plug.
Old Nov 3, 2003 | 08:15 PM
96 WS6's Avatar
It's a standard freeze plug you can just get one that measures the same and pound it in with a socket. I have mine out to install my CSI if you really want I can measure the opening.
Old Nov 3, 2003 | 08:29 PM
OZ DREAMER's Avatar
I ruined the freeze plug trying to put it in and did not want to run to the store so i used JB Weld...worked great and i have had know problems....
Old Nov 3, 2003 | 09:59 PM
NOMAD's Avatar
Cool
I placed a penny on the inside of the pump housing, jb welded on the front and back. Holds well and only cost me 1 cent
-Shannon
Old Nov 5, 2003 | 04:21 PM
jimlab's Avatar
Thanks!
Magenta_Hearts
Mar 29, 2017 08:54 PM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
Scottyboy
Feb 11, 2015 10:28 PM
Jul 4, 2005 05:00 PM
