Are optisparks really that bad?
Old May 25, 2003 | 01:35 PM
  #16
12SCNDZ's Avatar
Originally posted by PGR
Another problem with the opti is its lack of accuracy. When the engine & opti are new, things are OK. But as the timing chain stretches, and the splined drive pin wears, the amount of backlash between the crank and the optical wheel is quite large. This results in spark scatter (variations in spark timing). One reason older LT1's have a rough idle. The newer optis with the pin pressed into the cam have slightly less backlash, but timing chain stretch is still present.
The LS1 picks up its position signals from a large-diameter machined reluctor wheel on the crankshaft, so the tolerance stack-up or timing chain wear doesn't affect spark accuarcy.
Yes, but chain stretch affect ALL distributors, unless you're using a crank trigger. A typical V-8 engine runs the distributor off the camshaft... Rather it's in the front, back, or wherever. Yes, the exceptions are newer distributorless ignitions, but cam driven distributors have been around for a long time.
Frank
kmk7110
Jun 20, 2015 05:53 PM
jwade88
Jun 14, 2015 09:38 PM
ad356
Apr 11, 2015 11:12 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Injuneer
Dec 15, 2014 09:36 AM
