optispark testing
Old Jan 20, 2007 | 06:16 PM
ayers1967's Avatar
optispark testing
Anyone know how to test the optispark ? Did all the test in the hayes repair manual and it says the distributor or igntion module is bad. it says to take it to a dealer for repair. I'm working on a transplanted 94 lt1 into a 67 camaro .
no dealer in the country would touch it. Any help would be great .
Thanks , ayers1967.
Old Jan 20, 2007 | 06:52 PM
popstoy's Avatar
1-did the how did the motor run before the swap 2-what are the symptoms
Old Jan 20, 2007 | 07:43 PM
Mtrhds94Z's Avatar
With the opti out, hook it up [to wire harness] and [making sure that the BODY[aluminum housing part of opti] of it is touching GROUND, via engine block, or use a jumper] spin it by hand with ign ON and:
1] listen for injector 'ticks'
2] it should 'spark' also..
That's a basic test that I use and then when its installed before replacing WP etc I run it a few minutes..
Can it still be 'bad'? yup... but it still is a helpful basic test..
I know of no other way short of an oscilloscope, etc to really test it..
Old Jan 21, 2007 | 09:03 AM
ayers1967's Avatar
It was a totaled car that it came out of. I know the ecm is good I had it tested and all the egr,vats disabled.
Old Jan 21, 2007 | 09:11 AM
ayers1967's Avatar
And it will not start . No spark from coil wire. The white wire from the ecm at the module has no paulse.
Thanks again.
KYWes
Jun 14, 2022 06:52 AM
Girrrrl
Aug 20, 2015 06:17 AM
Aug 17, 2015 09:50 AM
karpetcm
Aug 14, 2015 03:02 PM
asilomar244
Jul 12, 2015 05:53 AM
