Optispark question
Old Apr 24, 2014 | 09:15 PM
1996LT1Z28's Avatar
Optispark question
Found the leak that was causing me pain...water pump seal not installed correctly..either way...
Using carb cleaner, I cleaned the whole front of the timing cover.
I then may have made a big mistake..I sprayed -off the optispark unit with the same carb cleaner and I may have gotten some cleaner to go down inside the connector.
Does anyone think I may have ruined the unit?
Could I take it apart and check it for any residue and clean it out?
Is the optical unit hosed?
Looking for advice / opinions.
Old Apr 25, 2014 | 02:20 AM
Fatdog2's Avatar
Re: Optispark question
Replace the water pump.The carb cleaner disapates instantly.Hope this helps.
Old Apr 25, 2014 | 10:58 AM
You indicate you got it wet with cleaner, but are there any symptoms of a problem - rough running, misfires, hard starting, etc.? If you have a problem, you will know it. If it's running OK, you don't have a problem.
Old Apr 25, 2014 | 11:02 AM
Keenan's Avatar
I assume you mean replace the water pump drive shaft seal? Why would he replace the water pump itself?
Old Apr 25, 2014 | 01:17 PM
pizzi-man's Avatar
to replace the seal in the timing chain cover for the water pump you have to remove the water pump and the opti. At this point I would also replace the opti seal and pull the opti apart and replace the cap and rotor and do any clean up of the opti. If it's the original water pump then it would be good insurance to replace that also.
Old Apr 26, 2014 | 07:16 AM
1996LT1Z28's Avatar
All the above was done. Thanks for the advice!!
Old Apr 30, 2014 | 10:16 AM
1996LT1Z28's Avatar
Glad I replaced the opti...
My original unit was in pretty poor shape.
Took the unit apart last night, and that thing was as dirty as could be. From the contacts being scaled & pitted to the oil and dirt, and lastly the bearing was pretty wobbly.
Looking for a replacement bearing, but I read where there are no guide grooves or anything like that when you press the two halves of the shaft apart -- so, I just might forget about the whole thing and just keep the optical sensor as a spare part.
Just thought it would be nice to have a spare unit just in case, but pressing the main shaft back together and getting it right on would be next to impossible. I would imagine that being very critical in terms of engine timing.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Injuneer
Dec 15, 2014 09:36 AM
brentbrowning01
Dec 3, 2014 10:36 PM
