optispark question
Old Sep 3, 2009 | 05:58 PM
kaoticcamaross's Avatar
optispark question
searched the forums and looked at what ever one had to say about the delco/msd/ect. But my mechanic said that i only needed the replace the cap and rotor. Car has been bucking since the mac header install. Should I go a head and replace the whole thing or just get the cap and rotor? Thanks guys in advance.
Wes
Old Sep 3, 2009 | 06:17 PM
moparman's Avatar
Did your mechanic pull the code(S), if so, what were they?
Old Sep 3, 2009 | 06:21 PM
man you got me. I never saw any codes. In fact I took the car there basically told him what all I thought needed to be replaced on the car and after 3 days he called and said exactly what i told him so not sure he did anything.
Old Sep 3, 2009 | 07:59 PM
sbs's Avatar
sbs
Wes
If he made that judgment based on having your optispark apart on his bench and seeing that everything but the cap/rotor is in good condition, then you only need a cap/rotor. If not, you need a new mechanic.
Old Sep 4, 2009 | 05:26 AM
Bucking after a header install will usually trace back to burned plug wires.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Injuneer
Dec 15, 2014 09:36 AM
brentbrowning01
Dec 3, 2014 10:36 PM
