Optimal compression ratio for an LT1
Old Jan 15, 2004 | 11:32 AM
Rodrigues's Avatar
I have a completely stock bottom end and I was curious what is the highest yet safest compression ratio you can run on 93-94 octane fuel in an lt1? I am getting the trick flow heads and milling them down to accomplish the raised compression, would you advise against this? The gasket will be .039"
The heads are a 61cc combustion chamber (not 64cc like their site and summit advertises)
These are the specs on the AFR heads so i would assume it wouldnt be much different
Angle Mill .008” per cc
Flat Mill .006” per cc
To attain getting 54cc I would have to mill the heads aprox .060" and with that much I will probably have to machine the intake anyways so why not go with a little higher c/r?
BTW: the heads have a 3/4" deck
Old Jan 15, 2004 | 12:14 PM
GreenDemon's Avatar
Stock LT1s run 10.5:1 and LT4s run 10.8:1. You could try 11:1 since you're porting the heads and have exhaust it should cut down on tendency to detonate. But I wouldn't go over that. My engine has done just fine on 87 before so you should be able to raise the bar a little without any probs...
If you're planning on boost or juice in the future I would head in the other direction, though, and drop it some...
Keep in mind that raising the compression will make everything a little more sensitive- if you have a bad sensor somewhere it will make it more likely to detonate than stock...
Good luck. I'm sure you'll be able to tell what your engine likes and whether or not you've crossed the line...
Old Jan 15, 2004 | 12:19 PM
rskrause's Avatar
Moderator
Depends on the cam you plan to use. What are your cam specs?
Rich Krause
Old Jan 15, 2004 | 01:34 PM
Rodrigues's Avatar
I am going to use the 230/236 cam on a 112 lsa, a .039" head gasket with a 4.125 bore, the advertised intake duration on the cam at .006" is 282. How close am I able to get to the recommended maximum of 8.5 DCR without detonating on 93? Assuming good timing as well.
Rich Krause
Old Jan 15, 2004 | 01:47 PM
Grease's Avatar
I have 11.86:1 compression on the stock bottom end. No knock retard at all with 92 octane. My heads were milled down to 50.5cc chambers and I use Felpro .039" heads gaskets. I use a GM847 camshaft.
Old Jan 15, 2004 | 02:08 PM
Rodrigues's Avatar
Good to know, it seems like 12:1 is the furthest most people dare to go, with similar setups.
Old Jan 15, 2004 | 02:19 PM
RE AND CHERYL's Avatar
Cool
I am going to use the 230/236 cam on a 112 lsa, a .039" head gasket with a 4.125 bore.
You might want to check, I don't think you can bore an LT1 block that far.
To a poind the bigger cam you use the more compression your motor will take as the increased overlap bleeds off compression.
Old Jan 15, 2004 | 02:22 PM
FacelessZ's Avatar
Sure you can.
Old Jan 15, 2004 | 02:23 PM
FacelessZ's Avatar
Gorgeous car! Great color!
Old Jan 15, 2004 | 02:40 PM
Rodrigues's Avatar
Read a bit closer
"a .039" head gasket, WITH a 4.125 bore"
Relating to the subject of mis-reading posts Jon Adis sent me this
Aoccdrnig to a rscheearch at Cmabrigde Uinervtisy, it
deosn't mttaer in waht oredr the ltteers in a wrod
are, the olny iprmoetnt tihng is taht the frist and
lsat ltteer be at the rghit pclae. The rset can be a
total mses and you can sitll raed it wouthit porbelm.
Tihs is bcuseae the huamn mnid deos not raed ervey
lteter by istlef, but the wrod as a wlohe
Old Jan 15, 2004 | 02:59 PM
N2OpwrdTA's Avatar
Rod...thats oldschool I got an email with that in it about 9months ago. Cool stuff.
Old Jan 15, 2004 | 03:07 PM
marshall93z's Avatar
thats neat...never seen it before!
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
pimpss96
Feb 12, 2015 01:28 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
