opti-spark still works!
Before I put my original opti on to my new motor, I took the opti to the car wash and power washed it for the ultimate test. Today I started my new motor for the 1st time...it fired up in an instant like a new car!
#1 I see at least 5 posts a week about someones opti got wet and then it dies. Mines has been wet plenty of times and I never had a problem. #2 I want to see just how long mines will last, my car is not a daily driver. #3 Like I said, this is only a test.
I guess I should point out that when I put the old opti on, I didn't put on the other accessories like the water pump and other stuff in case the opti didn't work. Working on my car is a hobby and not a neccessity...at least so far!
OK, now i am confused. you didnt put the water pump on? SO basically, you put the opti on, started the car and called it a success? Water dosent make it die on the spot usually, it corrodes the points inside, or kills the optical.
i've gone through many automatic carwashes and also been to many do it yourselfs...and have driven my car in the ran....very slight snow...maybe 2 days max....also had my engine bay sprayed down with some degreaser and then power washed and my opti is sitll treatin me fine at 65K...hopin it stays that way...
