opti spark question
Old Jul 27, 2006 | 12:01 AM
henryz28's Avatar
opti spark question
I was wondering what the symptoms of a fried opti spark are; other than not starting.Because my car will not start it cranks and cranks but it will not start.Their is no power gitting to the fuel pump and I have changed the relay.The car is also not getting a spark.I was wondering if their was something that cuts the power to every thing else if the opti spark goes bad.The SES light on the dash also dosent come on when the key is first turned to where the radio comes on but it is not cranked but all of the other lights on the dash do come on then go off in a few seconds.So far here is what I have tried I checked all fuses,Changed the PCM, and changed the fuel pump relay but the car still dosen't start.Please Help.
Old Jul 27, 2006 | 12:11 AM
1FstFormulaV8's Avatar
Re: opti spark question
Use the search feature. There are a lot of useful threads out there. More info needed on the vehicle.
Old Jul 27, 2006 | 12:27 AM
StephenDeli22's Avatar
Check fuel pressure?
Old Jul 27, 2006 | 12:37 AM
henryz28's Avatar
the car is a 1996 camaro z28 and I am not getting fuel pressure or spark.Also the smog pump dosent turn on ;it used to buzz when the key was first turned on but I there is no buzz now.
Old Jul 27, 2006 | 04:57 AM
throb's Avatar
Have you done anything (mechanical) to the car before this happened? Unless it's possessed by a demon, the problem is probably something electrical. Have you checkd the fuses and relays bothe underhood and dash mounted? I don't think these cars have fuel pump shut off switches like Ford vehicles, but maybe if the opti malfunctions, it prohibits the fuel pump from turning on too? Have a scan tool thrown on it and see if any trouble codes come up.
Old Jul 30, 2006 | 06:55 PM
henryz28's Avatar
Dose any one know what happens when the opti spark goes compleatly out.Dose it shutdown the Pcm?Because I have checked everything else and I am still gitting no fuel no spark and my air pump also never turns on..Or if their is a problem some where else causing no spark is their any way I can test the opti spark to see if it is good or not.Thanks
Old Jul 30, 2006 | 07:24 PM
ShowStopper540's Avatar
i ALSO have a 1996 Z/28 and just replaced my opti, the opti DOES NOT shut down the PCM, if i were you i would check into my key because no fuel pressure, spark or AIR pump signals are all signs that the security system is not being bypassed, the little chip in your ignition key may be failing, i would try this and see whats up, there are a certain amount of OHMs the key chip is supposed to let flow through it (i dont know the exact number, check into it) and if it will not do it, the security system will not let your fuel pump turn on, or let your motor produce 'fire' (spark)...either of these links might help you, good luck!
http://shbox.com/1/vats_bypass.jpg or http://shbox.com/1/how_tos.html
Old Jul 30, 2006 | 07:34 PM
henryz28's Avatar
I thought of that allready I went and bought a new key from GM and it did not help,but thanks for the link I am going to bypass the vats anywase so that I do not have this problem latter.
Old Jul 30, 2006 | 07:35 PM
henryz28's Avatar
I thought of that allready I went and bought a new key from GM and it did not help,but thanks for the link I am going to bypass the vats anywase so that I do not have this problem latter.Thanks
Old Jul 30, 2006 | 09:57 PM
1racerdude's Avatar
Sounds like ya got a/several blown fuse or the ign switch is bad.
http://shbox.com/page/index.html
Go here for info that might help or see if SpeedyGonzales will pop up he is good with the 'tricity on these cars.
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Injuneer
Dec 15, 2014 09:36 AM
nophix
Nov 30, 2014 10:26 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
