Opti spark issues
Old Oct 30, 2006 | 09:15 PM
udlose94z28's Avatar
Opti spark issues
My car is setting codes 16 36 and 42 on the snap on scanner. Its a 94 z28. These codes are high and low resoulation pulses and an est code. It cuts off while running down the road, it losses all its fire, so i blamed it on the opti and tore it all down, What is my best bet to go back with? An Accel or Msd or GM vented or nonvented? what do you guys think is the best?
Old Oct 30, 2006 | 09:22 PM
10secbuick's Avatar
vented is better than non vented, but there is a lot more to do than just buying a vented opti. msd is the best, but most expensive, and there is a thread on here comparing the accel to the oem replacement from gm. i know when mine goes out, ill be getting that coil pack conversion. hope this helps.
Old Oct 30, 2006 | 11:01 PM
ajlew9428's Avatar
since your car is a 94, youll have to get nonvented. Which limits your choices to Gm, msd, or conversion kit. I would just go w/ replacement from gm. From what ive been hearing, the msd unit isnt as reliable as everyone had hoped. unless you dont have a budget, then do 1 of the coil setups
Old Oct 31, 2006 | 09:30 AM
no, thats not the original motor thats in there, theres a 96 model motor with a vented opti, a nonvented opti came off my old motor but a motor with a vented one was put back. Ran fine for 3 or 4 months but now i have trouble
Old Oct 31, 2006 | 10:18 AM
3DFORMULA's Avatar
go with the GM part, there is no flaw or gamble to worry about, it is correctly made
Old Oct 31, 2006 | 10:39 AM
Bawls's Avatar
I just ran into the same issue. Seems the aftermarket companies don't have it just yet so I went with a stock replacement.
ajlew9428's Avatar
sorry. Next time your talking about something pertaining to the engine, specify engine year, not model
grabbem88
Mar 18, 2015 01:25 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
