opti-spark failure
Old Feb 19, 2007 | 03:25 PM
lt1street's Avatar
opti-spark failure
Ok guys let me start over i replaced the opti-spark b/c it failed no spark. I bought a gm opti from summit, it lasted 4 months, it started missing at rpms above 3000 rpms. I had summit send me a new one it was fine for about 8 months then it failed with the same miss at 3000 rpms. I then thought i would try the MSD opti work awsome (only three mounths old)till i parked to car for about two weeks. After sitting that long i went to start the car it fire up then died. NOw i no spark and i have check everything. i can up with that there was no signel be recived from the opti. also got code 16. My question is what should i do is it my car that is eating optis or is it bad parts ???? I have use alldata flow charts to check volt, ohms,....... list goes on i could not find anything wrong. please help.
Old Feb 19, 2007 | 03:37 PM
SantaCruz163's Avatar
eye theenk ur geramer hus sumting two du wit teh otpi buraking.
Old Feb 19, 2007 | 03:47 PM
2000GTP's Avatar
So you have a high rpm miss and you have replaced 4 optis and still have the same miss? Did you troubleshoot the problem where you declared that the opti is at fault or are you just throwing parts at the car?
Old Feb 19, 2007 | 03:55 PM
Texas_96_Z's Avatar
LOL. Nice picture of you SantaCruz, last time I saw a mouth that big it had a hook in it...
Formula Steve
Sep 19, 2023 08:31 AM
canuck94z28
Aug 19, 2015 05:50 PM
RUNMYTA
Jul 15, 2015 07:50 PM
Injuneer
Dec 15, 2014 09:36 AM
94DROPTOPZ28
Mar 1, 2003 02:44 AM
