Starting Problem..
Old Feb 19, 2007 | 04:21 PM
Sdimein's Avatar
Starting Problem..
Car has had a hard time starting recently.. it takes a couple attempts to get it to start or if i get heavy on the gas.. Looked under the hood and noticed that a couple fuel injector O-rings?? were very cracked and broken.. Im guessing this would have an effect on the starting?? If so.. what would be the easiest way of going about changing them ?
Old Feb 19, 2007 | 04:38 PM
2000GTP's Avatar
Pull the rail, replace the damaged injector o-rings, and make sure you put some type of lubricate on them before reinstalling the fuel rail.
Old Feb 19, 2007 | 04:43 PM
Sdimein's Avatar
ha..
easy enough..
Old Feb 19, 2007 | 04:49 PM
GMRL's Avatar
Also check the fuel pressure regulator for a leaking diaphram.
Just pull the vacuum reference line off, if gas comes out, its bad.
silvermansteve
Mar 4, 2015 05:02 PM
eazyZ
Mar 1, 2015 07:12 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
