opti spark blues
Old Aug 19, 2005 | 08:19 PM
totaltoy's Avatar
opti spark blues
Bought a 97 Z28 and it quit the day after purchace,Investigation revealed spark at coil but none at plugs.Removed distributor and found rotor completly mangled and lying in bottom of cap.I replaced with a new unit(Distributor) and it lasted another couple of day,s and the same thing happened!!The inside of the cap looks like there is not enough room and the rotor rubs until it fails.The opti unit itself is fine so it doesn,t look like the camshaft is forcing the distributor shaft forward so how do I set the rotor/cap clearance??These things are way expensive here and GM has been no help at all.I sure miss the points and condenser from my first Camaro!!
Old Aug 19, 2005 | 08:33 PM
Chris 96 WS6's Avatar
Re: opti spark blues
First, are you using brand new GM optis or rebuilt autozone crap?
Second, check the length of the drive pin coming out of the front of the cam. It shouldn't be more than like .33 past the cam sprocket. That may be shoving the rotor and causing misalignment problems.
Old Aug 21, 2005 | 08:11 PM
Whitewolf's Avatar
is it rubbing all the way around or on one side? mine is rubbing on one side..I replaced the whole opti this time and been ok..but waiting on it to fail..hope it doesn't. Just thought we might be the same problem.let me know..
bradleyluke@yahoo.com
Brad
Old Aug 21, 2005 | 08:47 PM
turbo_Z's Avatar
Did the previous owner install a different cam? Comp cams have a tendancy to install dowel pins that are too long which causing the opti to bind and break like you are describing.
beltrunner
May 17, 2015 10:18 PM
blkWidow
May 3, 2015 08:42 AM
grabbem88
Mar 18, 2015 01:25 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
