opti spark
Old Jan 26, 2006 | 11:56 PM
1clean9c1's Avatar
opti spark
its on the car.the car is not starting.my friend and i have checked everything.the only thing left is the opti.it has spark,fuel,compression,i changed the icm.ive tried everything.it cranks but wont start
Old Jan 27, 2006 | 12:17 AM
Chrisbequick's Avatar
Re: opti spark
If it has spark why do you thing it's the opti-spark?
-Chris
Old Jan 27, 2006 | 12:28 AM
1FstFormulaV8's Avatar
Re: opti spark
You're not getting something. If it has fuel and spark you'll hear it. It won't sound like a dead crank
Old Jan 27, 2006 | 12:38 AM
sbs's Avatar
sbs
Re: opti spark
You've opened half a dozen threads on this same topic in the last couple days. Keep the posts in one place so people can try to help you.
Old Jan 27, 2006 | 01:26 AM
ajschult's Avatar
Re: opti spark
Are the rockers properly adjusted? Is the coil good? My coil went out in the middle of my heads/cam swap for no reason.
Old Jan 27, 2006 | 01:42 AM
1clean9c1's Avatar
Re: opti spark
im new to this site.i kept going tp new thread instead of post reply. im getting used to it.sorry.ive had 20 people on here tell me even though it has spark that it can still be the opti.ive checked everything but the opti.fuel,compression,fuses,relays,spark,coil,chan ged icm.what else is left
Old Jan 27, 2006 | 11:53 PM
Re: opti spark
Have you considered having it scanned for codes? Lss of low res pulse pattern from the Opti will shut down the fuel system, causing non-start. I'd give you the codes, but you didn't bother to post any info about your car.... not all LT1's are the same, particularly the codes.
Suggestions:
1. Add a signature with basic info about your car - year, tranny, major mods, etc.
2. Post once, use "reply" when people respond. If you can't find your post, its probably slipped down a couple of pages. Click on the "search" button, put your screen name in the correct field, and it will find your posts for you.
jmadoll
Jun 10, 2015 04:41 PM
beltrunner
May 17, 2015 10:18 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
DTK
Aug 14, 2002 06:14 AM
