Opti-Spark
Old May 16, 2004 | 09:35 PM
94redz6sp's Avatar
Question Opti-Spark
Alright We trashed the idea of the 94 Z. But i just got the 95 Formula my uncle broguh up from Texas. One problem it doesnt run. There is no spark what so ever. We ordered the optispark and hopefully it will be here tomorrow. Any tips? how long should it take?
Old May 16, 2004 | 09:37 PM
DonHood's Avatar
Excellent step-by-step
Old May 16, 2004 | 09:44 PM
94redz6sp's Avatar
Thanks. An thing to watch out for? how long are they supposed to last. we ordered ours from gm so it should be top of hte line
Old May 16, 2004 | 09:45 PM
Bobs 94 TA's Avatar
that doesn't look so hard. God I wish I had a lift.
Old May 16, 2004 | 09:58 PM
GreenDemon's Avatar
Avoid spilling coolant allover it. The vented aren't as prissy about coolant as the non-vented (I've spilled coolant down there several times...) but it can still cause problems.
And they go out when they go out, but most people seem to have problems in the 60-100k mile range. Mine went out at approx. 81k.
Expect to have coolant everywhere. Draining the radiator is the easy part. When you take the hoses off the pump, more will dump allover you. When you start unbolting the waterpump, yet more will dump on you. Since you'll have everything out of the way already, I would suggest some new coolant hoses. And some new wires and plugs. It will be a lot easier with everything out of the way.
Old May 17, 2004 | 01:08 AM
Lt1t56's Avatar
Its really not too bad to replace but if it was me doing the repair I would also replace the Opti oil seal in the timing cover and the water pump drive oil seal in the timing cover, Felpro sells a timing cover gasket set for like $10.00. The Opti seal basically just pops out of cover and lightly tap new one in with hammer, the water pump drive seal a little more tricky but not hard. Do a search on water pump drive seal install to find out how, Iam not good at typing out how to do things, the water pump seal must be installed properly or you will have big oil leak.
Formula Steve
Sep 19, 2023 08:31 AM
Dizzy1
Parts Wanted
May 1, 2004 06:07 PM
Dizzy1
Apr 24, 2004 11:14 PM
LS1-Maniac
Oct 16, 2003 04:33 AM
94DROPTOPZ28
Mar 1, 2003 02:44 AM
