opti shaft
Old Mar 30, 2010 | 11:06 AM
95wannabe's Avatar
opti shaft
On this style opti..
http://shbox.com/1/93-94_opti.jpg
Is this shaft the same on both ends....so it doesn't matter which goes in opti & which goes in timing cover?
Old Mar 30, 2010 | 04:57 PM
Guest47904's Avatar
Guest
The other end of the shaft sticking out of the opti in the picture you posted is entirely different.
shown here: http://shbox.com/1/optical.jpg
Why would you ask the question?
Old Mar 30, 2010 | 05:01 PM
He means are both ends of the Opti splined shaft the same. I've flipped mine over when fiddling around with an old Opti, and the shaft seems so insert in either direction. I think there might be an O-ring on one end, but I can't remember.
Old Mar 30, 2010 | 05:29 PM
craby's Avatar
yep there the same. u should be able to put it in either way and be good to go. pretty sure the orings are on the water pump shaft only.
Old Mar 30, 2010 | 05:58 PM
95wannabe's Avatar
Thankyou
ryanhilsgen
9
Sep 21, 2015 07:34 PM
Jlo
Jul 29, 2015 03:52 PM
88IROC_Z
Jul 22, 2015 11:38 PM
RUNMYTA
Jul 15, 2015 07:50 PM
asilomar244
Jul 12, 2015 05:53 AM
