Opti rotor rubbing cap (pics inside)??
Old Nov 20, 2006 | 06:15 PM
Sweetred95ta's Avatar
I just pulled my opti off and decided to take it apart because I've been having problems with the car stumbling. Well, I disassembled my original (131,xxx mile) opti and this one (<1000 miles) at the same time. My original didn't look bad, but some of the posts were pretty worn. When I pulled the newer one apart, I found that the rotor was rubbing the car!! What can I do to fix this? Click on picture to make it bigger. Sorry for the crappy pics, all I have is a cell phone.
In this one, you can see the wheel is rubbing as well.
Old Nov 20, 2006 | 06:53 PM
wrd1972's Avatar
This can happen when the two tiny rotor scews are backing out.
Old Nov 20, 2006 | 07:13 PM
Javier97Z28's Avatar
Moderator
It can also happen when the dowel pin on the cam is too long.
Old Nov 20, 2006 | 07:24 PM
They didn't feel lose when I took the rotor off.
I would sure hope not. I thought I didn't have to worry about that having the vented opti.
I used pieces from my old opti and have pieced together a 'super opti' (iow, one that should work correctly).
Old Nov 20, 2006 | 07:31 PM
Moderator
Oh but you do! That's the opti where you *need* to be worried about the dowel pin length.. remember, it's what drives the opti (non vented opti's are not driven by the dowel pin).
My buddy's cc306 ground by comp has a "too long" dowel pin.. the opti only lasted a few thousand miles before destroying itself. I shaved the dowel pin on my LE3 (ground by comp) a little bit too.
Old Nov 20, 2006 | 07:41 PM
Do you know how long (approx.) it should be?
Old Nov 20, 2006 | 08:01 PM
Dave89IROC's Avatar
courtesy of the man, shoebox
Old Nov 20, 2006 | 09:31 PM
I think it is too long. I guess I'm going to mask everything off and try to cut it. I appreciate your guys' help.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
grabbem88
Mar 18, 2015 01:25 PM
squarehead
Nov 21, 2014 08:02 PM
omarECD
Aug 19, 2002 07:28 AM
