Opti Rebuild Kit
Old Sep 10, 2009 | 05:21 PM
SmokeyBlaZe's Avatar
Opti Rebuild Kit
I was looking at my terminals on my opti and they look pretty corroded and covered with green crap, So I heard to stay away from the MSD cap and rotor kit, what about This kit from thepartsladi? I would get a whole new unit for 260$ but I just dont have enough money in my pockets, Anybody use this kit? What makes it a "rebuild kit" http://cgi.ebay.com/ebaymotors/GM-OP...Q5fAccessories
Old Sep 10, 2009 | 05:26 PM
A cap and rotor are the basic parts. Looks like a dust shield with that one, too. Should be ok.
Old Sep 11, 2009 | 01:46 PM
Anybody have a link to a good write up on removing and replacing the cap and rotor
Old Sep 11, 2009 | 02:19 PM
rclearyiii's Avatar
Tools Needed
You will need a E4 (reverse torx socket) and a T9 torx bit. Just remove the 4 (E4) bolts from the cap..then use the T9 to remove the two torx screws that hold the rotor button on. Most people suggest using some loctite on the rotor bolts during installation.
Old Sep 18, 2009 | 06:07 AM
FireHawk409's Avatar
it seems my opti just went out. does the rebuild kit pretty much replace everything in the opti that needs to be replaced?
Old Sep 18, 2009 | 06:34 AM
No, it's just a cap and rotor.
Old Sep 18, 2009 | 07:16 AM
well i guess i'll just buy a whole new one, im not taking a chance with just replacing a few parts when other parts could be messed up.
Old Sep 19, 2009 | 06:16 AM
The "base" or back-half contains the bearing, the optical module and wheel, and the harness connector. All of those are prone to failure. Calling a "cap and rotor" a "rebuild kit" is misleading. Its just a cap and rotor.
Old Sep 19, 2009 | 06:26 AM
Guest47904's Avatar
Guest
To clarify: If you're having a problem with the 4 pin connector on your opti. The kit you showed will NOT fix that problem. You will have to change out the entire opti, not just the cap and rotor.
As far as a written procedure. It's easy to do and intuitive. Remove all the coolant you can before starting the job. Remove the crank pulley from the hub, the hub can stay in place. No need for any kind of puller.
See shoes website for more pics and so on.
Old Sep 19, 2009 | 06:43 AM
The terminal I was referring to was for the coil wire, I honestly havent looked at the 4 pin connector yet, thanks for the reply
Old Sep 20, 2009 | 12:43 AM
Should I put some threadlock on the rotor screws? It looks like it already has something on it.
Old Sep 20, 2009 | 09:10 AM
moparman's Avatar
Yep, loctite the screws.
Old Sep 26, 2009 | 12:13 AM
Just a heads up for anyone planning on buying this. The new fancy white dust cap locked in place and everything fine , but it wouldnt allow the opti harness to plug in...at all. Had to use my old dust cap.
Sergio
Jan 27, 2016 04:27 PM
blac94Z
29
Mar 25, 2015 04:21 PM
armedtrigger
Feb 24, 2015 08:30 PM
chuyz28
Nov 25, 2014 11:14 PM
