OPTI question for OBD2-OBD1
Old Dec 29, 2003 | 12:55 AM
Firebird355's Avatar
I am doing an OBD1 conversion on a 97 LT1, what do I have to do to connect the opti to the 94 harness? is there an adapter or something?
Thanks,
Joel
Old Dec 29, 2003 | 01:21 AM
ttt please someone, I need to know about this
Thanks,
Joel
Old Dec 29, 2003 | 01:44 AM
QCKZ28's Avatar
no adaptors, you just swap the whole computer. everything plugs up normally, the two computers even look the same
jesse
Old Dec 29, 2003 | 02:30 AM
yes, but I was told the Opti wouldnt plug into that harness, and I cant find a plug that looks like the one on the opti?
Old Dec 29, 2003 | 02:39 AM
QCKZ28's Avatar
the computer is located at the back of the engine compartent on the passenger side.
it has 4 connectors they are all color coded, you simply unplug the connectors from you PCM, and plug into the new PCM. very simple should not take over 10 minutes....
there is no special adaptors you need.
trust me, i have the OBD1 conversion in my 96
who told you that you needed a "special" adaptor?
dont believe everything ppl say.....
jesse
Old Dec 29, 2003 | 06:50 AM
There is a difference in the harness for the opti. Not sure what all you are changing, but just keep the opti harness that goes with the opti that you are using.
Old Dec 29, 2003 | 12:27 PM
QCKZ28's Avatar
i thought he meant just simply swapping computers
OBD2---->OBD1
jesse
Old Dec 29, 2003 | 01:09 PM
WS Sick's Avatar
I swapped from a 93 to a 95 OPTI (basicly what you are doing) and the small harness fron the connector on the pass side of the intake down to the opti has a different connector on the opti end, but on the wiring harness end it is the same. I simply went to my Local GM dealer and told them what I wanted, we looked at the breakdown and ordered the part new. It was a little ober 20$ for it.
As far as just the PCM then its pretty much a plug in.
Old Dec 29, 2003 | 01:44 PM
I bought the 97 engine with a chopped harness....therefore I cant just sawp computers.... I wish it were that easy lol, Ill have to check into it some more later on tonight when I get home, thanks for your replys.
Joel
Old Dec 30, 2003 | 12:13 AM
I still cant find a plug that looks right? Anyone have any pics? sorry if this sounds stupid, maybe its right in front of my face and Im just not realizing it
Sergio
Jan 27, 2016 04:27 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
grgguy
17
Feb 23, 2015 07:57 PM
Injuneer
Dec 15, 2014 09:36 AM
pologreen97z
Dec 2, 2014 10:42 AM
