Opti question
Old Apr 5, 2008 | 01:55 PM
jtarp's Avatar
Opti question
I am looking into getting a new opti spark and was wondering what else i should buy while doing this. If so if i buy an opti from summit will it come with everything i need for installation? car has over 100,000 miles so i'm guessing i should go ahead and change out the water pump also?
Old Apr 5, 2008 | 01:56 PM
2000GTP's Avatar
With that mileage and considering it has to come off, the waterpump is a good idea. It wouldn't hurt to do fresh plugs and wires also.
Old Apr 5, 2008 | 10:31 PM
jtarp's Avatar
What kind of water pump should i go with? Is there any advantage with going with an electric one as opposed to mechanical?
Old Apr 6, 2008 | 12:31 AM
96' Formula WS6's Avatar
I noticed a good SOTP difference with the electric waterpump. I would reccomend it especially since you will already have it off.
Old Apr 6, 2008 | 07:24 AM
2000GTP's Avatar
Its up to you, the electric waterpump has shown some decent gains on the dyno. Unfortunately, if they fail, they can do so quickly and without warning, where as a mechanical pump is a little more forgiving. There are audible alarm kits on the market that you can install as well which will alert you if a fault is detected. If you stick with a mechanical pump, I would just stick with another GM unit.
Old Apr 7, 2008 | 02:44 PM
jtarp's Avatar
Thank you for your thoughts. I think I will go with an electric mezeire pump from summit. thanks again.
Old Apr 8, 2008 | 11:36 PM
Lt1t56's Avatar
This would be a great time to replace the opti oil seal and water pump drive seal in the timing cover.
Sergio
Jan 27, 2016 04:27 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
grgguy
17
Feb 23, 2015 07:57 PM
Injuneer
Dec 15, 2014 09:36 AM
pologreen97z
Dec 2, 2014 10:42 AM
