OPTI question
Old Mar 3, 2005 | 09:37 AM
95_LT1_6SPD's Avatar
OPTI question
My waterpump was leakin on my opti and it started to act up. So my question is, will a cap and rotor rebuild fix the problem, or is it the sensors that get screwed when they get wet?
Old Mar 3, 2005 | 09:44 AM
fesgali's Avatar
Re: OPTI question
If your lucky nothing happened and when it dries it'll run normally. If you not lucky then you'll have to replace the cap/rotor and it'll be fine. If your day really sucks then you gotta replace the whole thing (cap/rotor/optical sensor).
Old Mar 3, 2005 | 10:45 AM
RE AND CHERYL's Avatar
Re: OPTI question
Same thing happened to mine when the pump went. I removed the cap and cleaned it out. No gaurentee, but it worked for me.
Old Mar 3, 2005 | 12:28 PM
chevroletfreak's Avatar
Re: OPTI question
RE and cheryl,
What did it take to just remove the cover? Did you have to remove the balancer?
Old Mar 3, 2005 | 01:10 PM
GreenDemon's Avatar
Re: OPTI question
Cap & rotor- hesitation, stumbling, knocking, backfiring
Opti- No start, rpm fluctuations
It's probably the cap & rotor, if the opti gets wet like that the computer loses it's only timing signal so it can't fire the injectors or the plugs. Some people have had luck with a hairdryer and others with alcohol to dry it, I've never tried it out though, my cap & rotor died from old age and got replaced.
Old Mar 3, 2005 | 02:23 PM
Re: OPTI question
I think i will just go with a new opti. You can get them for like $200 off ebay new. Thanks for your help guys
Old Mar 21, 2005 | 07:40 PM
dover179's Avatar
Re: OPTI question
How bad will it knock? I've got a knock and I've got oil leaking out of the timing cover. Could this possibly be the culprit? It's a pretty good ticking noise I've got and I can't tell exactly where it's coming from. I originally thought it was lifters since it's losing power too, but maybe it's the opti? I'm just hoping for the best I guess!
Old Mar 21, 2005 | 07:48 PM
neurotictim's Avatar
Re: OPTI question
For that matter, what would I need to replace the whole Opti system? I was thinking that MSD is usually a good bet, but what parts would I need - the control and spark module, what else? I'd do it myself, if I could, so is installation pretty easy to handle?
My Opti got a thorough Virginia Beach soaking, and stumbled and missed pretty bad for a couple of days - I'd just as soon not have to worry about that again...
Sergio
Jan 27, 2016 04:27 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
grgguy
17
Feb 23, 2015 07:57 PM
Injuneer
Dec 15, 2014 09:36 AM
pologreen97z
Dec 2, 2014 10:42 AM
