opti problems
Old Jun 13, 2005 | 01:34 AM
'94 Red Dragon's Avatar
opti problems
What are signs of a bad rotor cap or bad ing.
Old Jun 13, 2005 | 07:53 AM
Rashiki's Avatar
Re: opti problems
A misfiring engine (sometimes the SES light will blink), a bad miss/stumble below 2,500 rpms are a few.
Old Jun 13, 2005 | 11:34 AM
Re: opti problems
Its weak as hell especially in low rpm's. The SES light has came on and doesn't come back on when restarted. What does that code read.
Old Jun 13, 2005 | 11:48 AM
cas0484's Avatar
Re: opti problems
When my cap/rotor went out I had a slight missfire throughout the entire rpm band. Sometime it can be really bad and sometime not even noticeable, mine resembled a bad batch of gas. Turned out that #8 had little to no spark at all Goodluck!
Old Jun 15, 2005 | 11:39 AM
Rashiki's Avatar
Re: opti problems
When my opti gave up the ghost, it started out as a stumble in the low RPM's, but was still rock solid above around 2 grand. It then progressively broadened throughout the operating range of the engine.
If you put it on a scanner, it'll tell you what code it is, i dont' have it on the top of my head. you can also search for DTC's for your vehicle on the 'net or a book.
greenzee28
Mar 26, 2015 09:13 AM
grabbem88
Mar 18, 2015 01:25 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Injuneer
Dec 15, 2014 09:36 AM
