I can only go 130 mph
Old Jun 12, 2005 | 10:12 PM
tony_mid's Avatar
I have a '96 camaro z28 m6 and the fastest I can get it up to is 130 it doesnt shut the engine off or anything but it doesnt seem to go any faster than that does the mph just go up really really slow after 130 or should it be noticeably climbing?
Old Jun 12, 2005 | 10:15 PM
Bow94z's Avatar
Re: I can only go 130 mph
doesnt seem like you have the speed limiter because the speed limiter on these cars stops at 110mph.. maybe you have different gears than your aware of and are running out of gear
because my buddies car with 4:10's tops out at 130-135mph
Old Jun 12, 2005 | 10:17 PM
HardtopSS's Avatar
Don't shift into 6th, keep it in 5th till redline. I can tap out the 155 Speedo on my 97 M6, you shouldn't have any problems.
Old Jun 12, 2005 | 10:20 PM
tony_mid's Avatar
I'm not running out of gear or anything I still have like a 1500 rpms left to redline it just doesnt go any faster it does the same thing as my other v6 camaro except that one stopped going faster at 120 and then the check engine light came on.
Old Jun 12, 2005 | 10:23 PM
Bow94z's Avatar
hmm how are the plugs/wires/fuel filter?
Old Jun 12, 2005 | 10:24 PM
HardtopSS's Avatar
What gear were you in when it stopped pulling?
Old Jun 12, 2005 | 10:26 PM
tony_mid's Avatar
6th gear
Old Jun 12, 2005 | 10:28 PM
HardtopSS's Avatar
That's your problem, I shifted into 6th gear to and it just maintains the speed, keep it in 5th as long as you can. Like I said, I can tap out my Spedo, so you shouldn't have any problem. I just have a Stock SS with a K&N Airfilter and GMMG Catback.
Old Jun 12, 2005 | 11:31 PM
tony_mid's Avatar
alright next time i drive i'll try that and see if it helps thanx for the help
Old Jun 12, 2005 | 11:34 PM
JKDZ28's Avatar
Be carefull and keep it between the ditches
Like said before, keep it in 5th gear.
92rslt1's Avatar
yup you run out of power in 6th to move it. Why do you need to go 130 or faster anyway? I learned once the hard way its not a good idea.
Old Jun 13, 2005 | 12:03 AM
HardtopSS's Avatar
Yeah, I wouldn't reccomend doing it on anything short of an abandoned interstate late at night, with the assistance of a trusty Valentine One. I use I-85 North.
Old Jun 14, 2005 | 08:55 PM
976speed's Avatar
i have 97 Z28 and when i had my stock gears in, i could do 145 in 5th, and could bury it in 6th.
Old Jun 15, 2005 | 11:14 AM
limige's Avatar
i had mine to 145 in 5th, not enough power in 6th to go that fast.
Old Jun 15, 2005 | 11:56 AM
97formulakid's Avatar
You can't top your car out in 6th. I can bury the needle in 5th and then after that it pretty much runs out of power.
95chwagon
Oct 16, 2015 12:24 PM
4586
Sep 27, 2015 01:55 PM
MDZ28
11
Sep 24, 2015 09:15 AM
NewsBot
Sep 14, 2015 09:20 AM
mmf_1013
Sep 12, 2015 08:56 PM
