Opti Problem
Old May 6, 2004 | 10:24 AM
Sterlingsxe's Avatar
Opti Problem
ok guys here is a big problem for you. I just changed my opti. Ok so it went pretty well. So then i start it up. Had to jump it it was sitting for a while. Ok take it down the street. Wow driving nice. Ok give it a lot of gas. Revs up and putters im like o crap. And thne im like o **** i dont have a lot of tranny fluid in. Ok drive to the store pick some up pour it in. Now i rev and go fast its fine. Shut it off. Ok start driving again. Its 25MPH so im going 25. It goes up to 45 so i give it some gas. At 40 mph it wont go any faster. It just puts and puts but doesnt go n e faster. Itsnot even reving loud. I make it home some how cuz it feels like im going to stall. I open up my hood its liek 300 degrees under there. i feel one of the coolant lines and i burn myself. What could be the problem of this. It didnt missfire at first when i changed the opti. But now it wont go over 40 and its over heating. Did i change some wiring aroudn by mistake when i put it back together. Please get back asap
Engine
v 8 350 LT1
1994
Non vented opti.
Old May 6, 2004 | 11:03 AM
thermwood1's Avatar
Did you mean antifreeze, instead of tranny fluid?
When you put antifreeze back, did you make sure to open the bleed off valves?
Old May 6, 2004 | 11:06 AM
no i added anti freeze. and tranny fluid where are the bleeder screws for the coolant
Old May 6, 2004 | 11:09 AM
thermwood1's Avatar
http://shbox.com/1/4th_gen_tech1.html
This is Shoebox's web page. Under How To's, there is a coolant drain and refill procedure. Do this.
Old May 6, 2004 | 12:46 PM
Ok did it it worked. The temp of the engine is operating. But i just changed the opti. And now when i give it wot. It goes threw 1st gear with no problem. 2nd gear hits It just doest go. It just put put put put then i let off the gas and punch it again and it takes off. Then third gear comes it just stops accelerating and goes put put put in 3rd gear at like 60 mph. Since i just changed the opti. Could it be the wires? And i know there a bitch so what is the best way to get at them if it is.
TTT
Old May 6, 2004 | 05:50 PM
ttt
Old May 7, 2004 | 08:01 AM
thermwood1's Avatar
Is it throwing any codes?
Old May 7, 2004 | 08:09 AM
Dave Feerst's Avatar
its not the wires.
At WOT your trans should not be shifting into third till about 92 mph 2nd at about 42. if the engine RPMs are hitting the shift point of 5705 well before this MPH im guessing you are still low on tranny fluid.
Old May 7, 2004 | 08:14 AM
thermwood1's Avatar
Dave has a point. Since everything is good in first gear, it doesn't sound like a wire problem.
When you checked your tranny fluid, you did have the car running and the tranny warmed up, right?
Old May 7, 2004 | 01:15 PM
yea i did it was the ho2s uhh i took it to class this morning hooked upt he tech 2 scanner. THe bank one o2s has a low reading and when the car is for the first few min its in open looop and it fine, when it goes to closed its bad
greenzee28
Mar 26, 2015 09:13 AM
grabbem88
Mar 18, 2015 01:25 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Injuneer
Dec 15, 2014 09:36 AM
