opti nonvented, being replaced w/ vented is it compatable?
Old Oct 8, 2003 | 01:20 AM
NewbieWar's Avatar
well is it compatable to use a vented opti rather then a nonvented?
cause the vented one is cheaper isnt it?
is the vented one better?
Old Oct 8, 2003 | 01:28 AM
madwolf's Avatar
You have to swap the cam, the timing cover and the opti harness. You will also need the 95-97 vent tubes.
Most will say vented is better, but I've had good and bad luck with both, so I won't say which one is better, but yes, the vented one is cheaper.
I'd just go with a non-vented replacement if I were you.
Old Oct 8, 2003 | 04:47 AM
Fastbird93's Avatar
It's a pain to do the non to vented swap, but in addition to the opti being vented, you also get the freedom to run a Cloyes or a LT4 Extreme Duty timing set.
HectorM52
Jul 30, 2017 11:46 AM
*Emilia*
May 13, 2015 09:05 AM
grabbem88
Mar 18, 2015 01:25 PM
grgguy
17
Feb 23, 2015 07:57 PM
GigaMp3z
Feb 20, 2003 02:57 PM
