opti install ? 94 opti to a 95 block? change cam gear?
Old Oct 13, 2006 | 12:05 PM
4SFEDZ's Avatar
ok i am putting a new motor in my 94 lt1 and the opti is driven by a splined shaft on the back of the opti that goes into the center of the cam gear. that is how the 94 are right? ok and the new motor i have to put in it, is out of a 95 which the opti is driven by a dowl pin in the cam gear, correct? now could i just swap the cam gear off my old motor with the cam gear on the 95 motor to allow my 94 opti to fit it?
Old Oct 13, 2006 | 12:54 PM
Re: opti install ? 94 opti to a 95 block? change cam gear?
Yes, that would work. IMO, I would buy a complete, new timing set while I had it apart.
You're missing a good opportunity to swap over to a vented opti, though.
Old Oct 13, 2006 | 01:10 PM
94 NO TOP Z's Avatar
You'll need to swap timing covers also but, if you are doing the cam gear you will have it off anyway.
Old Oct 13, 2006 | 05:17 PM
4SFEDZ's Avatar
im using the opti (brand new or i would get a new vented) tc cover and cam gear from my old motor. so thats all i will need? thanks so much for the info im doing this this week end.
Old Oct 13, 2006 | 07:01 PM
Whatever you do, the opti, timing cover and cam gear have to be for the same type of arrangement-either vented or non-vented.
Old Oct 13, 2006 | 08:51 PM
4SFEDZ's Avatar
thanks alot, ya its all from the same car! is there any thing i have to know or do when switching out the cam gear? is it hard?
Old Oct 14, 2006 | 09:56 AM
sbs's Avatar
sbs
You're doing extra work to achieve an inferior setup.
I'd rather have a used GM 95+ opti than a brand new GM 94- opti.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Noenav
Dec 6, 2014 07:35 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
