ok, it ran fine for about 10 mins
I got the new TP sensor in there and a new battery since my last one was dead. It fixed my problem and it ran OK, a little rough with exhaust popping, until it did the old stall type feeling. it isnt set to a certain rpm, but it gets better when I change something, then goes right back to where it was before. My other posts about this problem are :
http://web.camaross.com/forums/showthread.php?t=472791
http://web.camaross.com/forums/showthread.php?t=473475
I am starting now to think it almost has to be the opti or a tooth off on the timing set, which I dont see how you can do that, but I guess its worth checking? I just hate to take off the water pump if I don't have to, I just got the coolant bled
but any advice is helpful, I cant really get it up to get it scanned, it just about dies and makes it hard to go the speed limit even.
thanks
thanks
Re: ok, it ran fine for about 10 mins
It would seem more likely that something less mechanical has changed. A connection issue, wire shorted or broke or burned like O2 wires on a header. If your going to continue to keep a Hi-po engine, it would be a wise investment to get some equipment to be able to see sensor data in real time.
ya, im about to get my mom's old laptop in 2 weeks so I can datalog it... they are going on a cruise tho tomorrow so its too late to get it before they go. The o2 sensor on the pass side is kind of burnt where the connection is... I am thinking this very well could be it... which one is bank 1? This o2 when I last scanned it was bouncing around like crazy... I think that must be the one that is the problem... I will replace it later today and cross my fingers.
thanks for the reply... if I have to wait for the data logger I will, but thanks for the help.
ok, the one not bouncing around is the driver side (sensor 2). I unplugged the O2s and it runs right about the same. How would I rule out O2s besides buying one and installing it? I am vey close to buying an opti, but want to rule out plug wires/o2s
thanks again
thanks again
Biggiebound
Apr 20, 2015 07:16 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
