Opti Harness Question
That link is for a 95 - 97, the 93 - 94 uses a different length connector that plugs into the opti so this harness won't work for you. Not sure if Casper makes the 93 - 94 style, but you can see from Shoebox's info below GM had 2 different part numbers:
1993-1994 optispark (non-vented)
electrical harness 12106559 $55.19
1995-1997 optispark (vented)
electrical harness 12130319 $67.70
If you are switching a 93/94 to "vented", you use the harness for a vented (95-97) Opti. The difference is the connector on the Opti, so the harness has to match the Opti, not the model year of the car.
Yeah that is what I thought. You think I would know I just went over this with ya'll.
Sergio
Jan 27, 2016 04:27 PM
