Opti Harness Question
Old Mar 7, 2007 | 08:46 AM
LTgun_94's Avatar
Is this universal? Will it work on a 94?
http://www.casperselectronics.com/Me...Category_Code=
Old Mar 7, 2007 | 09:38 AM
OBE1 95Z28's Avatar
That link is for a 95 - 97, the 93 - 94 uses a different length connector that plugs into the opti so this harness won't work for you. Not sure if Casper makes the 93 - 94 style, but you can see from Shoebox's info below GM had 2 different part numbers:
1993-1994 optispark (non-vented)
electrical harness 12106559 $55.19
1995-1997 optispark (vented)
electrical harness 12130319 $67.70
Old Mar 7, 2007 | 10:44 AM
The two harnesses do not interchange.
Old Mar 7, 2007 | 10:57 AM
LTgun_94's Avatar
Thanks...that all i needed to know!
Old Mar 7, 2007 | 11:05 AM
snakeatinZ's Avatar
So what should 94 guys use to switch to vented????
Steve
Old Mar 7, 2007 | 11:25 AM
If you are switching a 93/94 to "vented", you use the harness for a vented (95-97) Opti. The difference is the connector on the Opti, so the harness has to match the Opti, not the model year of the car.
Old Mar 7, 2007 | 12:39 PM
snakeatinZ's Avatar
Yeah that is what I thought. You think I would know I just went over this with ya'll.
Sergio
Jan 27, 2016 04:27 PM
jayvar
Feb 2, 2015 10:00 PM
Injuneer
Dec 15, 2014 09:36 AM
pologreen97z
Dec 2, 2014 10:42 AM
