Opti Dowl pin
Old Jan 13, 2006 | 04:50 PM
Split's Avatar
Opti Dowl pin
The opti dowl pin it not line to line, depending which way you install the pin it is eather advanced or retarded a little. Which way is correct??
A friend of mine had it the wrong way, and his car wouldn't start, we searched for the problem for weeks, and finally figured out that it was the opti dowl.
Old Jan 13, 2006 | 04:59 PM
OBE1 95Z28's Avatar
Re: Opti Dowl pin
The opti drive pin only has one correct location; see photo from Shoebox's site:
http://shbox.com/1/opti_back.jpg
Old Jan 13, 2006 | 05:00 PM
Re: Opti Dowl pin
I don't understand much of what you said, but the dowel pin sits in the cam only one way and it is supposed to go in only one place on the opti. There is no advance or retard.
Old Jan 13, 2006 | 05:10 PM
Split's Avatar
Re: Opti Dowl pin
SIG is wrong for my car, so i didn't post with it
ITs a 94 Z-28 NOT a 97
sorry for the confusion
On the 93-94 opti's they had a short dowl/ splined pin, on both sides they had two pins right next to each other so you couldn't install it wrong, BUT if you turn the pin around and take the side that was in the motor and put into the opti the car wont start, if i recall one side of the splined dowl is offset from the other side, make it advanced or retarded, if you turn it around. Not sure which way is correct?
Old Jan 13, 2006 | 06:00 PM
OBE1 95Z28's Avatar
Re: Opti Dowl pin
Here's Shoebox's photo for the 94:
http://shbox.com/1/93-94_opti.jpg
Old Jan 13, 2006 | 10:37 PM
Re: Opti Dowl pin
You were talking about dowel pins, so who was supposed to know? I have never heard of anyone having a problem with the splined drive.
tdigger9899
Sep 7, 2015 10:56 AM
reww86
Aug 29, 2015 06:04 PM
Schul365
Aug 22, 2015 10:00 AM
asilomar244
Jul 12, 2015 05:53 AM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
