how can i get a bigger lope?
Old Jan 13, 2006 | 10:18 PM
colossus's Avatar
i recently finished my h/c with LE2 heads and a cc306 and it has a little lope to it, but i've heard soundclips of other people with the cc306 and the lope just sounds nasty. is there any pcm tuning that i can get done to it to get a bigger lope? like would lowering the idle speed help me out there? or would lowering the idle speed be bad on the motor? right now its tuned from PCMforless, so idk if anybody knows what he sets his idle speed at and if it can be lowered. Thanks
Old Jan 13, 2006 | 10:30 PM
Re: how can i get a bigger lope?
You can look at the desired idle speed and actual idle speed with a scanner. Maybe you have a situation where it is not maintaining the set idle speed when hot.
Old Jan 13, 2006 | 10:32 PM
AdioSS's Avatar
West South Central Moderator
lower the idle speed
Old Jan 13, 2006 | 10:41 PM
1racerdude's Avatar
Put in a 260/270@50 on a 108+4 and it will lope plenty.
Turn the idle screw CC until it will just idle in gear with the air on and try it.
magman
Apr 15, 2016 03:08 AM
Hal Fisher
Sep 30, 2015 09:03 PM
95craz28
11
Sep 12, 2015 07:47 AM
nd4spd200
Aug 21, 2015 09:30 AM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
